"No suitable GPU device found!" on dual RTX2080 config...
  • "No suitable GPU device found!" on dual RTX2080 config...
    Upon running Vantage i get this error:
    "No suitable GPU device found! A DXR-compatible device is required."
    See attached picture.
    As you can see the system has 2 RTX 2080 cards.
    I'm using latest nvidia game drivers (Dec 8 2020) and Windows version 1803.
    Any ideas how to fix this ?
    Thanks,
    Greg
    Could you share the file %APPDATA%\Chaos Group\Vantage\debug_log.txt please?
    Is there anything unusual in your setup, like virtual machine, remote desktop, etc?
    Nikola Goranov
    Chaos Developer
      Here's the log:
      Chaos Vantage v1.0.0 (build 857539, hash 049e19ff)
      Build date: 2020.12.02
      Window initialized in 1007.1 ms
      NVIDIA driver version 8.17.14.5751 detected.
      Driver check: OK
      System memory: 63.89 GB
      Windows version is 10.0.17134.
      Device #0: NVIDIA GeForce RTX 2080, 7920 MB (DevId=0x1E87, SubSysId=0x37A71458 )
      Device #1: Microsoft Basic Render Driver, 0 MB (DevId=0x8C, SubSysId=0x0)
      Can't use device #0 - no raytracing support (0x80070057). Skipping.
      No virtual machine, nor remote desktop.
      The only "exotic" thing about this computer is that it is under heavy firewall security by our IT, but so far i had no problems with any other 3d app or plugin.
      Thanks,
      Greg
        Weird thing that it detects the 2nd card as "Microsoft Basic Render Driver"...
        Hmm...
        Edit: Maybe i should disable the SLI nVlink perhaps? I doubt its doing anything with these low end cards.
          Nope, disabling SLI and restarting, didn't do jack.
          I'm getting the same error..
            Ah, yes, I should have noticed in the first post. You stated yourself the Windows version is 1803 (log: "Windows version is 10.0.17134."). The minimum requirement is 1809 (build 17763) -- this is when DXR was added to Windows.
            BTW, the device is listed once in the log because in the DirectX world this is considered one "device" with two "nodes".
            We've discussed this in other threads - NVLink improves the maximum possible framerate when using two devices because it avoids the slower PCI-e bus between them and they need to transfer rendered pixels on every frame. However it does not double the effective memory available for the scene. This is subject to future research and development...
            Nikola Goranov
            Chaos Developer
              Right...
              I was afraid it had to do something with the Windows version.
              Nothing i can do about that; i'm in the mercy of the IT to deploy the newer version, but this may take 6 months or more.
              Things are pretty slow on big corporations when it comes to operating system updates.
              Thanks anyway,
              Greg
                Hello to all, it is similar problem with Nvidia V100, where Vantage took both cards as Microsoft Display.
                This is log>
                Window initialized in 558.2 ms
                NVIDIA driver version 8.17.14.6109 detected.
                Driver check warning: Driver 461.09 is newer than the latest tested version which is 460.89
                System memory: 61.00 GB
                Windows version is 10.0.17763.
                Device #0: Microsoft Basic Render Driver, 0 MB (DevId=0x8C, SubSysId=0x0)
                Click image for larger version  Name:	Clipboard01.jpg Views:	0 Size:	126.5 KB ID:	1099171
                OS is Windows Server 2019 ver 1809
                Do you please any tip how to fix it, please ?
                  Vantage requires an Nvidia RTX GPU. This V100 is an older generation GPU.
                  Nikola Goranov
                  Chaos Developer
                    The most likely reason for Vantage not seeing the GPU, even though it's listed in Device Manager, is that the GPU is in TCC (Tesla Compute Cluster) mode.
                    You can read about it here : https://docs.nvidia.com/nsight-visua...tesla-products
                    You can use the nvdia-smi.exe tool to check and change the mode. See attached screen-shot.
                    Still, like Nikola said, we don't officially support Volta GPUs since they lack RT cores and performance won't be very good.
                    However, If you switch the GPU from TCC to WDDM mode, Vantage should be able to see it and use it.
                    Greetings,
                    Vladimir Nedev
                      Thank you, I see Volta is not able to get in WDDM mode. How many GPUs is possble to use in Vantage, please ? I tested it with 8x2080Ti but in bottom right corner of Vantage window was sign 2xGPU.
                        Vantage is currently limited to 2 GPUs. This is mainly because the bus interface between the cards becomes a bottleneck and doesn't scale well.
                        Nikola Goranov
                        Chaos Developer
                          Hi I'm using Nvidia Geforece GTX 1650
                          and when ever I'm trying to launch the Vantage It's showing "No suitable GPU found! A DXR compatible device is required."
                          pls help
                            pls help
                            I think nVidia never enabled the DXR API for the GTX 1650 because of its low performance.
                            You can read more about which GPUs have DXR support here : https://www.techpowerup.com/254528/n...force-gtx-gpus
                            Greetings,
                            Vladimir Nedev
                              Hm, actually, that article I linked was before the 1650 was released.
                              It's hard to find info whether DXR is enabled on the 1650 or not.
                              In any case, it lacks the RT cores, so performance will be very bad and we don't "officially" support it (even though Vantage would run on it, if DXR is available).
                              Greetings,
                              Vladimir Nedev
