Live Link in Vantage 1.0 less responsive?
  • Live Link in Vantage 1.0 less responsive?
    I just tested the first installment of Vantage 1.0.0 I work in 3dsmax using a 3DConnexion space mouse with the live link to Lavina/Vantage set up. I'm using a single rtx3090.
    In Lavina 0.6.0 that worked very well, almost without any frame drops. Now in the latest release when i move with the spacemouse in 3dsmax, the live link only updates when i stop moving in 3DsMax.
    Is it something i could fix in the preferences/registery or is this a not intended side effect which will be fixed in the next update?
    Greetings, Jakob.
    Supposedly there shouldn't be any change in this regard between 0.6 and 1.0 .
    Can you go back to 0.6 and confirm that it updates immediately without having to stop moving in 3dsMax ?
    Have you installed a new version of V-Ray for 3ds Max or 3ds Max since you last tried the 0.6 build ?
    Greetings,
    Vladimir Nedev
      Hi Vladimir,
      Thanks for your quick response!
      Nevermind, I found the problem, I was navigating in a V-Ray Camera. If I just move in perspective mode, it behaves like before!
      Greetings, Jakob.
