animation frames render freezes at 98~99% for 30sec
  • #16
    I got something....it happens when I pause the render....and than continue
    • #17
      aborted the render, changed nothing, renderd again and no problems. I think it has something to do with the pausing thing,...
      So resumé; 2560x1440- 456 frames....no problem rendering in 1 go. Paused it and then resuming....problem starts...
      • #18
        OK, so pausing is suspect. But did you use the pause when the original issue occurred? We will try to reproduce this with pausing.
        Nikola Goranov
        Chaos Developer
        • #19
          yes, I'd probably paused the animation in the original issue
          • #20
            We were able to reproduce the issue by pausing the render. It is related to video encoding and it adds exactly 20 seconds per frame. I will post when we have progress.
            Nikola Goranov
            Chaos Developer
            • #21
              The issue is fixed. This fix will be included in the next patch update, coming soonTM.
              Nikola Goranov
              Chaos Developer
              • #22
                Please download the latest update 1.0.2 - it should fix this issue.
                Nikola Goranov
                Chaos Developer
