Chaos Vantage & NVIDIA Studio Driver Version 460.89
  • #16
    Just saying the 461.40 Studio Drivers are released. Don't see the normal release notes document other than some ads for laptops.
    V-Ray 6 Beta | Intel i9 9900K | 64GB | 1x 512GB EVO 970 Pro SSD | 1x 1TB Kingston Nvme | 1x 4TB Lexar Nvme | 2x 6TB SATA | 1x 4TB SATA | 1x RTX 4090 24GB + 1x RTX 3090 24GB
    • #17
      I had some issue(s) with my account and couldn't log in earlier, but now everything's set.
      About the 461.40 SD drivers, I have installed'em and the issue with the texture is still present only on Ampere GPUs...
      • #18
        We released an update today - 1.0.2 - which fixes some of the issues with the 46x.xx drivers (specifically with ColorCorrection and UVWGenChannel). They might work ok now, but we're still issuing the same "unsupported driver" error because we are not certain there aren't other unsolved issues with these drivers. If you'd like to test, just ignore the warning.
        Nikola Goranov
        Chaos Developer
        • #19
          That's wonderful news! Installed the 1.0.2 and loaded a scene and all the textures seems to working like before
          In my case all textures with ColorCorrection seems to work 100% correct.
          • #20
            I just found out that the V-Ray TriPlanar texture is also broken with the 46x.xx drivers. It's most likely the same driver bug.
            There is no fix for the TriPlanar texture in the 1.0.2 update, so if you plan to use it, you will have to go back to the 457.09 driver for now.
            Greetings,
            Vladimir Nedev
            • #21
              Thanks for the tip Vladimir, I will try to avoid V-Ray TriPlanar textures until the issue will be fixed.
              It is such a shame that the latest Nvidia drivers introduced (probably unintentionally) so much bugs...
              It is also sad that the NV SD Drivers are no longer what they once were...
              • #22
                After we reported the bug to nVidia, they fixed it pretty quickly and the fix is in the 461.72 driver.
                The TriPlanar texture should be working fine with that driver.
                Some V-Ray for Maya specific textures were also broken with the previous 46x.xx drivers and are now working fine with 461.72.
                Greetings,
                Vladimir Nedev
                • #23
                  Greetings,
                  Vladimir Nedev
                  That's wonderful news Vladimir!
                  I'll install the drivers ASAP.
                  • #24
                    I've installed the drivers and tested Vantage. Now it's working like a charm with no issues at all
                    • #25
                      We have confirmed that driver 461.72 is good. It is now marked as supported and will no longer cause a warning to be displayed.
                      Nikola Goranov
                      Chaos Developer
