Live Link doesn't work
  • Live Link doesn't work
    I can't send scene to Vantage through the Live Link. In all cases nothing happend. There is no issue when sending vrayscenes.
    Here is the log
    https://www.screencast.com/t/bIu69Zm9x
    Are the ports the same in Vantage and 3ds Max ?
    What's the "status" of the live link, i.e. what does the last row of the "Live Link" menu say ?
    Also note that you have to be running V-Ray 5 in order to use the live link.
    V-Ray Next is incompatible and Vantage won't connect to it.
    See here : https://docs.chaosgroup.com/display/LAV/Live+Link
    Greetings,
    Vladimir Nedev
      I assume you are following the instructions here: https://docs.chaosgroup.com/display/LAV/Live+Link
      There may be relevant information (warnings) above the error in your screenshot, like this:
      Is Vantage listening on the same port?
      Nikola Goranov
      Chaos Developer
        What do You mean "are the ports the same in Vantage and 3ds Max"
        And other words - how to check the ports for 3ds max?
        here is the last line of live link
        https://www.screencast.com/t/0udH5lR6g
        Regards,
        Michal
          When you specify a DR server, you also specify the port to establish the connection on.
          Vantage is a type of DR server.
          If you are using the 3ds Max scripts for the live link that come with Vantage, the port is 20701, so it is matching.
          Greetings,
          Vladimir Nedev
            Apologies. Problem solved
              Here is a screen from the 3ds max and Vantage - as You can see there is the same port both on 3ds max DR server and in Vantage - but whenever I'll try to send the scene through the live link nothing heppend
              https://www.screencast.com/t/7mjkk71m10mT
                Could you check if your firewall allows connections? Also, could you screenshot all the messages in the 3ds Max messages window? Your initial screenshot was only 3 lines and there may be relevant info above them.
                Nikola Goranov
                Chaos Developer
                  Hi katana_poland
                  In addition to what Nikola said, can you please check what is written in the "IP address" column in the V-Ray GPU DR settings dialogue when you click on "Resolve"?
                  Alexander
                  Alexander Atanasov
                  V-Ray for Unreal & Chaos Vantage QA
                  Chaos
                    Hi Alexander and Nikola
                    Thank You for quick reply!
                    The problem was resolved. I don't quite sure what was the issue but I had to reinstall system and it helped.
                    Regards,
                    Michal
                      Hello I have same problem,
                      https://prnt.sc/12b6qsh
