error driver after hotfix 1
  • error driver after hotfix 1
    after hotfix installer i have this problem:
    driver version 460.89 is not supported.
    Now i have some problem of uw mapping in my files.
    I have one nvidia rtx 3090
    Yes, the latest drivers cause wrong renders on the latest 30xx cards, so we blacklisted them. You should downgrade to a previous driver version.
    Nikola Goranov
    Chaos Developer
      Today's update 1.0.2 includes workarounds for some of the issues with the new drivers. It will still give a warning, but the UV mapping should work now. We're not sure if there aren't other bugs with these drivers - that's why they are still marked as unsupported.
      Nikola Goranov
      Chaos Developer
        Driver 461.72 has solved the remaining issues. You can safely use this version.
        Nikola Goranov
        Chaos Developer
