Motion Blur dosent work in high quality render
  • Motion Blur dosent work in high quality render
    I moved this topic to this section, after not getting any respond and Im sure that is an issue.
    It works more or less in real time (with artifacts and wrong amount of MB) but in offline it dosent work at all.
    3090 + 2080ti (457.09)
    https://forums.chaosgroup.com/forum/...se-motion-blur
    Hi Paul
    Sorry for the late reply.
    You are correct, it is a bug that is occurring when utilizing 2 GPUs. Can you please try to use using just one of the cards to see if the issue persists? You have to do a manual set up for this at the moment. Start Vantage like this
    Code:
    vantage.exe -d 0
    to use the 3090 or
    Code:
    vantage.exe -d 1
    to use the 2080 ti.
    You could also use this argument in a desktop shortcut for easier use.
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
      Thank you, using one GPU does the trick.
      Appart from that current it seems that MB is very egdy and got a lot of artifacts .Click image for larger version
        The issue with dual GPUs will be fixed in the next Vantage update.
        Nikola Goranov
        Chaos Developer
