Livelink installation with 2 versions of 3DS Max
  • Livelink installation with 2 versions of 3DS Max
    I run both Max 2021 and 2018, when installing Vantage I select all boxes and it shows up nicely in Max 2021.
    It does not show up in Max 2018. Am I doing something wrong? (Vray 5.0 on both as well.)
    To be honest: I don't even know for sure if 2018 is supported.
    Thanks for letting me know! (If there is a manual work around, perhaps by moving some plug-in files from 2021 to 2018, please let me know as well.)
    Have a nice weekend!
    Hi Yard2380,
    The installer only supports and detects 3Ds Max 2021, 2020, 2019. You could manually copy the following file:
    Code:
    [LIST][*]%localappdata%\Autodesk\3dsMax\2021 - 64bit\ENU\usermacros[LIST][*]Chaos_Vantage-UtilityFunctions.ms[*]Chaos_Vantage-VantageImportChanges.mcr[*]Chaos_Vantage-VantageLiveLink.mcr[*]Chaos_Vantage-VantageTransferAnimVrscene.mcr[*]Chaos_Vantage-VantageTransferStaticVrscene.mcr[/LIST][*]%localappdata%\Autodesk\3dsMax\2021 - 64bit\ENU\usericons[LIST][*]VantageToolbar_16a.bmp[*]VantageToolbar_16i.bmp[*]VantageToolbar_24a.bmp[*]VantageToolbar_24i.bmp[*]VantageToolbarDark_16i.bmp[*]VantageToolbarDark_24i.bmp[/LIST][/LIST]
    and paste them accordingly to:
    Code:
    [LIST][*]%localappdata%\Autodesk\3dsMax\2018 - 64bit\ENU\usermacros[*]%localappdata%\Autodesk\3dsMax\2018 - 64bit\ENU\usericons[/LIST]
    That should make them appear in Max 2018.
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
      Thank you very much, this works!
        I am having a trouble getting the Livelink buttons to show up at all. We tried the process listed above with no success. Any chance there's something we are missing?
        Max 20 vray 5
        dav
          In V-Ray 5 update 1 the Vantage toolbar is part of the V-Ray for 3ds Max installation and as far as I know it doesn't have the issue which started this thread.
          Do you have the update ?
          Greetings,
          Vladimir Nedev
            Installing the latest Vray5 worked. Thank you.
            dav
