Animation keyframes
  • Animation keyframes
    Do they not get AA applied to them...? I see jagged edges in the final pngs. https://youtu.be/QAmJBsW0bso
    Also...How do I stop the dancing noise?
      What do you mean AA applied to animation keyframes ?
      I see jagged edges around the bright light sources - one way to fix this is to add some bloom to the image.
      Do you mean the glossy reflections on the stove at the very beginning ?
      You can increase the Samples used to render each frame.
      How many did you use by the way ? The animation looks generally noise free.
      Greetings,
      Vladimir Nedev
        I used 800 samples. I was trying to keep my times below 3 min. Look at the chairs near the kitchen. They dancing.
          Hm, yes, kind of strange that the chairs would have the extra noise. The youtube compression is probably not helping to see exactly what's going on.
          Did you use a noise threshold ?
          Maybe if you increase both the noise threshold slightly and the max samples, you will shift some of the calculations to the noisy chairs without increasing the render time by much.
          Greetings,
          Vladimir Nedev
