No materials - VRScene sketchup export
  • No materials - VRScene sketchup export
    Hey guys, when exporting a vrscene sketchup to the new version, there are no materials.
    RTX 3060, latest drivers.
    V-Ray for Sketchup exports native Sketchup materials as baked raw textures which we do not support yet in Vantage. Looks like that is why your material is missing. It is on our TODO list to implement raw bitmap support.
    Nikola Goranov
    Chaos Developer
      Hi vanja_uri,
      In addition to what Nikola said, V-Ray export not only native sketchup textures(from the materials library) but all textures that have no valid file paths as baked raw textures which Vantage doesn't support. Please make sure that all textures have proper paths which can be accessed in disk and you should see them in Vantage when you load the .vrscene.
      Alexander
      Alexander Atanasov
      Chaos
        For me, no textures work at all. The screenshot was made using a default sketchup library floor.
          From what I understand you can fix the paths from Extensions > V-Ray > File Path Editor. All textures of native Sketchup materials are like this - Sketchup loads them from memory by default, so the workaround is to use this dialog to export them to files. You should be able to click "Archive and repath" there and the items would initially show up with a yellow icon.
          https://docs.chaosgroup.com/display/...le+Path+Editor
          Nikola Goranov
          Chaos Developer
            Ok, but it does not work. The texture is still not visible. I used a single native vray texture, all paths are OK, and even Archive and repath it.
              Could you share a simple scene so we can investigate, please? I assume you are using Vantage 1.1.0, correct?
              Nikola Goranov
              Chaos Developer
                Hey, yes 1.1.0 indeed.
                Sketchup 20.0.363
                Vray 5.10.01
                Sending the scene now. Both sketchup and vrscene
                Dropbox is a free service that lets you bring your photos, docs, and videos anywhere and share them easily. Never email yourself a file again!
                  Hi vanja_uri,
                  From the sent .vrscene I can see that there is a Mtl Override used and applied to all geometry. If I export a new vrscene from the skp file, the scene looks fine in Vantage:
                  Have you by any chance used the Mtl Override functionality?
                  Alexander Atanasov
                  Chaos
                    Hey, I did not do any Mtl Override. I just opened sketchup, drew the box and applied the texture.
                    Can I take a look anywhere else?
                      How are you exporting the .vrscene ? Can you try doing it again while making sure "material override" is disabled ?
                      Greetings,
                      Vladimir Nedev
                        OK, so there are two ways to export a vrscene from Sketchup: Either from the asset editor render button drop-down choice or from the Export Proxy button by choosing "scene mode". Apparently Vanja used the latter. And it seems there is a bug in V-Ray for Sketchup - their team is investigating.
                        Vanja, try exporting from the asset editor instead:
                        Nikola Goranov
                        Chaos Developer
                          Hello, vanja_uri ,
                          It looks like you've stumbled upon a scene export bug in V-Ray for SketchUp. So far we were aware of it only occurring on macOS.
                          As my colleague Vladimir already requested, could you please describe in detail how the vrscene export was done?
                          Kind regards,
                          Peter
                          Peter Chaushev
                          Let's keep in touch
                            The easiest way is to show it. Please check the video:
                            https://www.dropbox.com/s/ietufir2fwxwvgm/123.mp4?dl=0
                            I opened a fresh window of Vantage, and of Sketchup and vray.
                            I exported it trough the toolbar originally. Material override was off.
                            When I export trough the asset editor, I can not find the object in Chaos Vantage at all. Might have to look into that, not sure what is happening since I never used that way of exporting.
                              The random export behavior bug in V-Ray for Sketchup has been fixed. This will be included in the next VfS update which is due next week if all goes to plan.
                              Nikola Goranov
                              Chaos Developer
