Frames
  • Frames
    When I export a 900 frame animation, it is only rendering 720 frames. What am I missing?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Let me guess, you exported at 30 fps from 3dsMax, but didn't change Vantage's default sequence FPS which is 24? Vantage can render at different framerate compared to what was configured in the original vrscene. Double check the value in the "render sequence" dialog.
    Nikola Goranov
    Chaos Developer
      BINGO! You are right.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        We don't have the FPS info available in the .vrscene file as far as I know, but maybe we should add it, so we can change it automatically in Vantage when you load a .vrscene.
        Greetings,
        Vladimir Nedev
          Greetings,
          Vladimir Nedev
          Definitely add it please!
          http://www.glass-canvas.co.uk
            Turns out we do have the FPS info in the .vrscene file.
            Our latest internal Vantage builds already read it, but we have yet to release a build with this change.
            Greetings,
            Vladimir Nedev
              The build we just released (1.2.0) will load the FPS setting from the .vrscene file.
              Greetings,
              Vladimir Nedev
