Repeated keyframes
  • Repeated keyframes
    I'm running into an issue when saving out my animation. I always get the same keyframe rendering in the beginning of my sequence and end. Like it'll render 27 keyframe 0 and a similar amount of the end frames. How do I tell it to just render one frame and move on to the rest of the keyframes?
    Could you explain in a bit more detail what you are rendering: for example, is it a camera movement recorded in Vantage itself or did it come from the vrscene? Is it a plain vrscene animation or you used the Vantage animation editor?
    Could you also copy the SettingsOutput plugin from the vrscene file? It contains parameters about the animation range.
    Nikola Goranov
    Chaos Developer
