error line 5479 during live link
  • error line 5479 during live link
    Hi, in some scenes i have this error and livelink don't start.
    Can you halp me?
    I think you should ask in the 3dsMax forum. This error is not directly related to Vantage.
    Nikola Goranov
    Chaos Developer
      I think the problem is due to Vantage.
      Let me explain:
      The render gpu or cpu in 3ds max works perfectly.
      he problem occurs if I use the live link and if, instead, I try to directly export to vantage 3ds max crash.
        Well, Live Link uses V-Ray's distributed rendering code. So there is maybe an issue in this part of V-Ray, but it's not in Vantage code for sure. I assume your other renders that worked are not DR.
        Whoever is going to debug this, they will need a way to reproduce the error, so it would be best if you could share a scene. And which exact versions of Vantage and V-Ray you are using. If you're not using the latest V-Ray (there is a very recent update available), try updating.
        Nikola Goranov
        Chaos Developer
          TKX,
          I used vray 5 update 1.1,
          after the last update the problem is over.
            Hi poliedrostudiosrl_pol,
            Are there by any chance any IES lights in the scene? Because there is an issue with them which we already discussed in this thread: https://forums.chaosgroup.com/forum/...24#post1109724 and here:https://forums.chaosgroup.com/forum/...-does-not-work which should be fixed in V-Ray for 3ds Max, update 1.2
            Alexander
            Alexander Atanasov
            V-Ray for Unreal & Chaos Vantage QA
            Chaos
              Hi Alex,
              yes I have IES light in the scene.
              After Update 1.2 the problem is over.
              TKX,now I understand the problem !!!
