missing materials when loading vr scene to vantage from sketch up
  • missing materials when loading vr scene to vantage from sketch up
    some materials are missing when I import vrscene to vantage.using latest version of sketchup up and latest version of v ray and vantage.trying to upload screenshots but system won't let me.
      Hi stathis_lazarides,
      Can you please send us a sample scene with just a cube and the bricks material assigned to it? There is an issue with UVs coming from sketchup and I would like to check and confirm this is the case here.
      Alexander
      Alexander Atanasov
      V-Ray for Unreal & Chaos Vantage QA
      Chaos
        I have managed to use a different material because i was in a hurry.
        But i have lots of other problems when i transfer v ray scenes to vantage.
        For example bricks come out as glass / reflective materials, timber planks and paving slabs come out really small sizes, leaves of trees come out incorrectly, trees missing, fireflies....
        Shall I pack a project and send it?
          We will need a scene for this. Maybe you have a Blend material on them ? We don't support it currently.
          This is most likely the (V-Ray for SketchUp specific) issue we are aware of, but still a scene might be helpful.
          You have to enable clip opacity - it's the "leaf" icon on the main Vantage toolbar.
          Support for the 2-sided material, which is usually used on leaves, is coming soon.
          trees missing
          Again, we will need a scene.
          If you are referencing a .vrscene file from your SketchUp file, this is something Vantage doesn't support currently.
          fireflies....
          If you have a sun in your scene, it might help to make it "invisible". This fixes fireflies issues with V-Ray too.
          Greetings,
          Vladimir Nedev
