Refraction gradient map
  • Refraction gradient map
    Refract Texture is supported in the Chaos Vantage support list below.
    https://docs.chaosgroup.com/display/LAV/3ds+Max
    If use a simple gradient texture for Refract Texture with IOR 1.0, the result will be different from V-Ray GPU.
    Click image for larger version  Name:	vraygpu.jpg Views:	0 Size:	275.2 KB ID:	1113408Click image for larger version  Name:	vantage.jpg Views:	0 Size:	176.7 KB ID:	1113409
    Is it simply a Chaos Vantage engine limitation?
    Scene attachment
    Confirmed in v1.2.1
    OakCorp Japan - Yuji Yamauchi
    oakcorp.net
    v-ray.jp
    Hm, I am not able to reproduce the issue here. Seem to be working correctly.
    What happens if you reload the scene ? Restart the operating system ?
    Just a note, procedural textures in the refraction slot will not be calculated for the purpose of shadow transparency.
    In your case the gradient is a bitmap file, so it's ok.
    Greetings,
    Vladimir Nedev
      What GPU driver version are you using by the way ?
      Greetings,
      Vladimir Nedev
        Can you please try with the denoiser off? There are some limitations to the denoiser regarding refractions and this may be causing this
        Alexander
        Alexander Atanasov
        Chaos
          Geforcce RTX 3070 with Studio 461.72.
          And Refraction textures are bitmaps (included in the attached zip)
          Oh, as you pointed out. Is this the Optix Denoiser spec? If so, it's NVDIA's job.
          I hope that this restriction will be removed in the future.
          Click image for larger version  Name:	2021-05-12_131143.jpg Views:	0 Size:	172.7 KB ID:	1113497
          oakcorp.net
          v-ray.jp
