UVW Randomiser issue
  • UVW Randomiser issue
    It seems that using this in the bump slot doesn't work, as in these grabs,...it works in a regular render just fine.
    They are Diffuse only/no randomiser, Diffuse only, with Randomiser and then Diffuse/Randomiser with the bump, which the same randomiser isn't affecting.
    Right now Vantage supports only bitmaps with "Explicit channel" UV mapping for bump mapping.
    Any kind of texture/UV source that goes through the shading graph system (like UVW Randomiser) is not supported for bump mapping.
    We did some work in this direction, but it gets quite complicated and potentially slow, so we postponed it.
    Greetings,
    Vladimir Nedev
      Ah ok, thanks...was driving me nuts trying to figure out what was going on
      I'll find another way.
