Denoiser control when rendering high quality sequence
  • Denoiser control when rendering high quality sequence
    I've noticed that when rendering a high-quality sequence the denoiser is set to 1.0 - Can I set how much denoiser I want for rendering sequence just as I can when I'm moving around the viewport? Denoiser at 1.0 generates a lot of splotches and glitches.
    Hi jellyjuicelondon,
    When rendering High Resolution Snapshot and High Quality Sequence the denoiser amount will be either 0, when disabled or 100, when enabled. There are no mid values.
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
      https://forums.chaosgroup.com/forum/...90#post1121590
      Nikola Goranov
      Chaos Developer
        Thanks both Nikola and Alexander!
