I try to export VRSCENE from 3ds Max with point cache of ANIMA AXYZ charactor but they don't walk in the Vantage. How Can I do?
How vantage using character animate such as ANIMA AXYZ or Point Cache or GrowFx animate?
Any update on this at all?
Many thanks,
ChrisCheck out my (rarely updated) blog @ http://macviz.blogspot.co.uk/
www.robertslimbrick.com
Cache nothing. Brute force everything.
Hi Chris,
Support for deformable meshes from vrscene is still not implemented. However, you can try the Render animation via Live link(check the docs here: Render animation with Chaos Vantage Script) feature which exports every frame from Max to Vantage and renders it out.
AlexanderAlexander Atanasov
V-Ray for Unreal & Chaos Vantage QA
Chaos
Great
Alexander.Atanasov please confirm we can render ANY animation in this way with Vantage
So if we had Madcar in Max, Populate People, ANIMA People, GrowFX wind, RayFire physics and fracture animation, tyFlow fractures etc
Anything works as long as it is rendered to Vantage from within Max using the "Render Animation with Chaos Vantage Script"?
Anything that is NOT supported yet?
Kind Regards,
Morne
Hi Morne,
Anything works as long as it is rendered to Vantage from within Max using the "Render Animation with Chaos Vantage Script"?. If you send us a basic sample scene that illustrate your setup we can test it and inform you if everything should render fine. One thing that is not supported in Live link is animated vrmeshes(VRayProxy), animated image sequences (ifl, movie files, etc). It will not update each frame so if that is what you are using or have in your setup it will not render as expected.
AlexanderLast edited by Alexander.Atanasov; 30-05-2022, 04:47 AM.Alexander Atanasov
Chaos
Originally posted by Alexander.Atanasov View PostHi Morne,
I can neither fully confirm nor deny. If you send us a basic sample scene that illustrate your setup we can test it and inform you if everything should render fine. One thing that is not supported in Live link is animated vrmeshes(VRayProxy), animated image sequences (ifl, movie files, etc). It will not update each frame so if that is what you are using or have in your setup it will not render as expected.
Alexander
Well there goes that idea.....
Will it be supported in the future, or its too expensive performance wise to have animated proxies?Kind Regards,
Morne
We do plan to support animated proxies when rendering High quality(offline) sequence at first. They will not update while navigating though the scene though. Performance wise - it will slow down rendering and probably increase memory usage but that is a guesstimation. We will inform you when there is some development there but no current ETA.
Chaos
- Likes 1
then I fix inside vantage but when I render the images, they come out without the tone mapping. Any idea why? using vantage 2
If you restart it, all the render settings will be reset to defaults.
You can save/load a vantage file as config during a live link.
Greetings,
Vladimir Nedev
