Vantage issue with Cosmos Library
  • Vantage issue with Cosmos Library
    This began happening when I opened the cosmos library, the process is not complete and I get this error. Check the attachment. What can I do? thanks!
    Can you show is the beginning of the debug log ?
    Greetings,
    Vladimir Nedev
      It seems that instead of the file Qt5WebEngineCore.dll in the Vantage directory, some other version of this file was found and used. Vantage takes measures to avoid this (it sets the process "current directory" so that dlls can be found there), so I don't know how this could happen. Is there anything unusual in your installation, e.g. are all the Qt dlls present in the Vantage folder, is it in the default program files location, etc?
      As a workaround, you could use Cosmos from an external browser by opening http://localhost:30305/
      Nikola Goranov
      Chaos Developer
