Working with animating some cars from the Cosmos library and am having an issue when animating the tire rotation. We have a script that will rotate a vehicles tires based on the vehicles position/speed along a path which works fine when rendered in Max, but Vantage is causing some odd scaling when the vehicle gets up to speed. The tire will scale from 100% to about 50% over a couple of frames then go back to 100% over and over until the rotation slows. I thought it might just be our script introducing some kind of keyframe noise or something, so I animated a stand-alone tire with just a keyframe at the start and end of the timeline and am getting the same results.
Any idea what's going on here? Vantage scene attached of just the basic tire animation
