1.51 update - 3DS max 2021 does not recognize the Vantage plugin any longer.
  • 1.51 update - 3DS max 2021 does not recognize the Vantage plugin any longer.
    When I install the new update I can no longer see the chaos vantage plugin in Customize UI any longer.
    Hi cameron_rule,
    Yes, we have removed them from the Customize menu as they are easily accessible through the Vantage toolbar that is coming with the installation of V-Ray 5 for 3ds Max, update 1 and later versions.
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
      Hey Alexander,
      Is this an update that is already released? Or is it still coming out?
      Cheers,
      Cam
        Update 1 has been released since March and the latest release is update 1.3 since October 1st, 2021 and there is also an upcoming update with a new functionality that is related to Vantage - Render animation via Live Link.
        Alexander
        Alexander Atanasov
        Chaos
          Thanks so much for the info, Alexander! I understand now. If you and the team are interested, I've been using Vantage to do architectural rendering for clients! Couldn't be happier with the software you are all creating! Some of my vantage work is below (most of the latest ones)
          https://drive.google.com/drive/u/0/f...NVCCVLHmnhFbBW
          Cheers,
          Cam
