Vantage Live Link from Rhino 7 not working - Stuck in command prompt
  • Vantage Live Link from Rhino 7 not working - Stuck in command prompt
    Latest Rhino 7.11.21293.9001 + Vray for Rhino 5.2 + Vantage 1.5.2 (Build: 1200713)
    Watching the video (link below) It looks like after clicking the "Starts a Vantage Live Session" button in Rhino the Command line briefly shows "Command options (IP=127.0.0.1c Port=20701): _-Render" then blank and the viewport in Rhino is linked to Vantage.
    When I click the "Starts a Vantage Live Session" button I get the Following:
    Command: _vrayVantage
    Command options ( IP=127.0.0.1 Port=20701 ): _Enter
    Starting Chaos Vantage...Done
    Command options ( IP=127.0.0.1 Port=20701 ): _-Render
    Then "Command options ( IP=127.0.0.1 Port=20701 )" remains in the command line no matter what I press - I can't select anything in Rhino or run any commands - I can only navigate the viewport (which is not linked to the current Vantage session).
    The only way to unlock Rhino is to close Vantage or (if I had them open) click the "Abort rendering" button in the Vray Options or Frame Buffer.
    It doesn't seem to be file specific as far as I can tell.
    Just confirmed it works correctly in my install of Rhino 6.35.21222.17001
      Can you post this in the V-Ray for Rhino section of the forum ?
      It seems the issue is on the V-Ray for Rhino side of things.
      Greetings,
      Vladimir Nedev
        Will do, Thanks Vladimir.
        I've been playing around with Vantage and Live Link in Rhino 6 the past couple of days and I must say that for me this is an absolute game changer! Amazing!!
