AXYZ 4d people
  • AXYZ 4d people
    I have a scene in 3ds max that contains 4d people from axyz and live link vantage. First of all the viewport in max gets too luggy, not responsive. Secondly when rendering the animation with the new live link animation render, every 10 frames i get one where the vertices of the 4d people are totally destroyed and then continues normal for few frames until it destroys again.
    Hi digital_technologies,
    Does this happen only when running Vantage or regardless?
    Yes, we are aware of the issue and we are investigating it. We will inform you when there is a fix for it.
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
      My 3ds max scene containing 4d people runs smoothly on the viewport of 3ds max, but as soon as i run vantage live link it gets luggy.
      thnaks
        The lag is probably happening because the max viewport and Vantage are using the same GPU and are fighting for resources, it will be the same if you try V-Ray GPU IPR. One possible solution is if you have 2 GPUs to tell Vantage to not use the GPU that the monitor is attached or plug the monitor to a GPU that will not be used for rendering.
        Alexander
        Alexander Atanasov
        Chaos
          Dear Vantage team
          Even when i do as you suggested problem not fixed.
          As soon as I run vantage, lagg starts to happen with axyz people. Even if i shutdown vantage the problem persists and viewport of max is very slow.
          Then i have to reset the scene in max and viewport gets responsive again.
          Thanks
            Can you send a video of how is it behaving before and after you run Vantage?
            Alexander
            Alexander Atanasov
            Chaos
              https://drive.google.com/file/d/1Lq_...ew?usp=sharing
                My intention is the following:
                As soon as I am able to have 3ds max viewwport running smooth with 4d people while running vantage, then I will be manually moving to next frame and print screen. This process again and again will cover a sequence of frames which I will comvbine in premiere to get the animation.
                But now even moving to next frame is very slow, impossible to work with.
                  What GPUs are you using ? How much system RAM ?
                  Greetings,
                  Vladimir Nedev
                    Dear Vladimir
                    My question is general as well.
                    I mean is it supposed that 4d people in 3ds max work with Vantage live link?
                    Have you tried it out in your team.
                    Cause in my case as soon as I import even one 4d people 3ds max viewport becomes very slow.
                    I need to mention that I am using anima all subscription.
                    Thanks again for your help
                      We have tested and they work fine on our end without lag. Here is a test video:https://ftp.chaosgroup.com/support/s...9_13-26-13.mp4
                      It is very strange that this lag is happening only after you have started Vantage and doesn't stop after you close it. Does it happen if you start a DR GPU IPR session with other machines, because Live Link with Vantage is just that?
                      Alexander
                      Alexander Atanasov
                      Chaos
                        Dear Alexander
                        Thank you very much for your reply and persistant help on the forums.
                        The videos that you sent me shows anima rigged people.
                        I think the problem comes with 4d people.
                        4d people use allembic format optimized by axyz to capture in 3d each frame of a 3d character movement.
                        Can you please check with these people and let me know if at your end there is no problem still.
                        Thanks a lot in advance.
                          Yes, I confirm that with 4d people the lag is reproducible on our side. This is also happening when using GPU IPR. When you said that the lag is continuing after you stop Vantage, have you closed the Live link connection first with the button in Max, or you just close Vantage? If that is the case, if you closed Vantage without stopping the live link connection first, Max is still sending data and IPR is running in the background. Can you confirm if you stop the live link from the button the lag stops or continues?
                          Alexander
                          Alexander Atanasov
                          Chaos
                            Dear Alexander
                            Thank you very much for your suggestion to close live link.
                            Then the max viewport goes back to normal.
                            Please try to solve this issue with rendering 4d people. It is the only thing missing to being able create the most amazing archviz short films.
                            Thank you all the team for all the effort and support you are giving us.
                            • #15
                              Any updates with the Anima meshes going mental? It's happening on their regular rigged characters (not 4d characters)? It seems to happen only on the copy and pasted Anima people, must be something in the Anima core?
                              Cheers,
                              Jason
                              AMD Threadripper 3990x 64C Processor, 128 GB DDR4-3200 Ram, 48 GB PNY Quadro RTX A6000, ​Windows Pro 10.0.19045.5796, 3dsmax 2025.2, Vray 7 Hotfix 2, Vantage 2.7.1​
