live link animation using Vantage UI not working
  • live link animation using Vantage UI not working
    Dear Vantage team
    I have a scene in 3ds max with animated noise deformation on a teapot.
    As soon as I create a camera and render animation with live link to vantage using 3ds max setttings the deformation animation is rendered.
    When i hit the the render animation with vantage ui, then sequence, the animation of the noise deformation neither any other kind of animation (moving , rotating) is not rendered. It starts rendering but the same frame, all over.
    Can you let me know if this is a bug, or there is somethign that i am doing wrong
    Thanks a lot
    Yes, it's a bug. Does the dialog within 3ds Max work for you, as an alternative?
    Nikola Goranov
    Chaos Developer
      Thanks for letting me know.
      Yes 3ds max dialogue works perfect.
      Only disadvantage of 3ds max dialog is that is not as well thought and intuitive way to render your animation.
      You need to create a camera, you cannot save as mp4.... all those nice settings that vantage team has prepared.
