So I guess using 3ds max's noise map isn't supported in Vantage? I added it to my bump slot in order to fake some refraction blur since that's not supported either.
3ds Max noise map
Bump mapping in Vantage supports only bitmaps, as computing the derivatives for other types of textures can be costly.
The noise map is otherwise supported, you can use it in all the other slots.
Greetings,
Vladimir Nedev
- Likes 1
