I was rendering an animation and what i noticed is denoiser overpowering the scene and causes splotchy in the scene which really weird..is there anyway i can control the denoiser like in Vray VFB? I'm providing the screenshots below
Denoiser cannot be controlled. Too much splotchy in the scene
Please read this post by Nikola
https://forums.chaos.com/forum/chaos...39#post1136739
Also, the bump mapping in your render might be too strong, because Vantage doesn't render it the same way V-Ray does.
So, instead of disabling bump mapping (like Nikola's post suggests), you can try decreasing the bump multiplier.
Greetings,
Vladimir NedevLast edited by vladimir.nedev; 15-01-2022, 09:07 AM.Vantage developer, e-mail: vladimir.nedev@chaos.com , for licensing problems please contact : chaos.com/help
My suggestion was not to disable bump to fix this issue. Please read carefully. I suggested making a comparison between renders with and without "reduce flickering" without bump to see the general sharpness difference.Nikola Goranov
Chaos Developer
