Triplanar not working on bump slot
  • Triplanar not working on bump slot
    i encountered a problem that triplanar map is not working on bump slot but works really well on diffuse slot...is this an issue or it will only work on diffuse??
    Bump mapping in Vantage works only with bitmap textures, everything else, like the TriPlanar texture is not supported for bump mapping.
    The TriPlanar texture will work in any slot, but not for bump mapping.
    Greetings,
    Vladimir Nedev
      Hey all.
      I was just about to ask a question about procedural noise in the bump map slot, but clearly this is a known limitation currently based on your reply. I hope procedural noise in the bump slot is something that will be implemented at some point? It's something we use quite a lot to add small details to products surfaces.
      Thanks,
      Andy
