Disordered camera names on the Render setup drop down camera listing
  • Disordered camera names on the Render setup drop down camera listing
    Ok, this is a minor thing but could be nice to get it fixed. In the Render setup window, the pop down list of cameras shows the camera names in a chaotic or random way. I got 55 cameras in a scene, named with just digits from 01 to 55.
    It is confusing the random way the drop down menu display the camera numbers: 03,22,26,11....etc. It doesn´t make sense when the cameras are named in perfect order.
    The order should be the same as in the "Camera" tab. Isn't it?
    Nikola Goranov
    Chaos Developer
      Hi Nikola, I have all cameras numbered from 01 to 55 but they appear random on the pop down list of cameras. Shouldn't they be following a numerical or alphabetical order? It is not a huge deal, just confusing with so many cameras. This won´t be an issue when "send all cameras to queue" will be available.
        Hi cadman5,
        I have logged in your request and will inform you when this improvement becomes available.
        Alexander
        Alexander Atanasov
        V-Ray for Unreal & Chaos Vantage QA
        Chaos
          There is some sort of misunderstanding here. As I said, the order is the same as in the camera list in the left side panel. It is not random and works as intended. See screenshot below. Cameras can be reordered by drag-and-drop in the camera list (here I moved #4 up a couple of slots).
          Nikola Goranov
          Chaos Developer
            Ok, then the issue would be the cameras re-ordering themselves random on the left? Strange since cameras from 1 to 10 in my case follow a linear path and are 2.2 m apart. Yeah, ordering manually is a bit of a chore with 55 cameras.
