Camera Switch Issue
  • Camera Switch Issue
    I usually set all the cameras in 3ds max and then I switch them one by one in 3ds max which reflects in vantage after which I create the same exact in vantage. Sometime When I try to switch the camera in 3ds max, it doesn't always work in vantage. This workflow is important for me as I sometimes render orthographic renders as well for which I have to set the camera in 3ds max with 0.5mm lens.
    Hi Alokpatil,
    That sometimes happens when you have the Max view maximized and the export gets mixed up. Here is a video that illustrates that behaviour: https://drive.google.com/uc?id=1oJ83...Jz1_HmqAspAB-r
    To fix this either do not have other viewports look through cameras or do not maximize one. Please check if it works on your end.
    Alexander
    Alexander Atanasov
    Chaos
