Will you consider allowing the layer content of 3dsmax to be turned on in the vantage interface during real-time connection?
Because turning on the layer in 3dsmax can easily cause 3dsmax to slow down, if you can pass the speed advantage of vantage. It might be better.
Then the final setting passes Save vantage configuration file?
