Reduce flickering
  • Reduce flickering
    Hello
    This option will open the image blurred, and the flickering situation has not improved very well
    Below with comparative files.
      Hi darling_my,
      At how many samples are you rendering the sequence? The 'Reduce flickering' option is not very suitable when dealing with very small details and sometimes(as in your case) blurs them significantly because the denoiser determines them as noise.
      Alexander
      Alexander Atanasov
      Chaos
        Originally posted by Alexander.Atanasov View Post
        Hi darling_my,
        Alexander
        HI.Alexander Atanasov
        The sampling of these two images is 2000
          Also, about the problem of animation flickering, is there a good solution?
