Render animation live link using Vantage UI
  • Render animation live link using Vantage UI
    Dear Vantage team
    There are several setting that dont work when rendering live link animation using Vantage UI.
    First it starts with 1 fps, and when you export the movie it is as slow as this 1 fps. If you can make default 24 fps, or when i change it to keep this change, as it does with resolution and samples..
    Then when you change to 24 fps, it automatically adjusts the start and end frames. then even when i set the starting frame to 60 it does not make a difference the rendering starts at frame 1.
    Plus I would like a way to render every second frame, cuase ii am using AI interpolation to save time.
    In general AI interpolation can be a thing that Vray can adopt the same way you have adopted AI Nvidia denoiser and lead to amazing reduction of rendering time.
    Hi digital_technologies,
    The 1 fps value is set this way so that the start and end frame matches that of Max and works well with image sequences but not with mkv/mp4 movies. We will look into it but in the meantime you can try to export the animation as image sequence and in you post editing app (premiere, after effects, ec.) set the FPS so that it is interpolated correctly.
    For your suggestion for exporting every nth frame we have an issue but haven't begin work on it yet.
    Alexander
    Alexander Atanasov
    Chaos
