When I set the frame range of 3dsmax to the starting frame other than 0 frame,
For example, 75-175 (01) in the figure below
So when I use real-time link and start sequence rendering through the plug-in in 3dsmax, I have set the same 75-175 as 3dsmax,
But when I click OK, vantage tells me that the sequence to be rendered is 175 pieces (02).
But it should be 100.
Then in this case, vantage will stop after rendering the first image. Subsequent images are no longer rendered.
Another plug-in that pops up rendering settings in vantage, which I have also tried, will also lead to an abnormal number of frames.
01:
02:
01:
02:
