Abnormal shadow part of VRaylight Plane light
  • Abnormal shadow part of VRaylight Plane light
    My scene contains 400 vraylights. When I turn them all on, my scene appears abnormal dark parts. When I randomly delete half of the lights, the abnormal dark parts disappear.
    When I cancel the shadow generated by vraylight, the abnormal dark part disappears
    When I set directional to 0.3, the symptoms were relieved.
    I try to turn on all the lights and render in Vray. It's normal.
    So I realized it might be vantage's problem
    Can you send us the scene or try disabling Clamp sec. rays and check if that solves the issue ?
    You can also try increasing the clamping value.
    Greetings,
    Vladimir Nedev
      Click image for larger version  Name:	clamp.PNG Views:	0 Size:	33.6 KB ID:	1148806
      Greetings,
      Vladimir Nedev
      I've tried to turn it off or on. It doesn't work.
      I'll prepare the scene files these days. Because it hasn't been published yet, I can send it to vladimir.nedev@chaos.com
      After sending, I will reply here to remind you to check
        Yes, send it there, thanks.
        Greetings,
        Vladimir Nedev
