Render Animation with Chaos Vantage error
  • Render Animation with Chaos Vantage error
    I use this plug-in. Set the same value of the start and end frames to render the still frame image. After rendering many times,. This error occurred
    MAXScript Rollout Handler Exception
    -- Known system exception
    -- Address 0x22ad0479; nCode 0x00000000C0000005
    -- Desc EXCEPTION_ACCESS_VIOLATION The thread tried to read from or write to a virtual address for which it does not have the appropriate access.
    -- Read of Address 0x0000000000000008
    OK
    Most likely the system ran out of memory (it could be a memory leak). Since the error comes from maxscript, it means that 3dsmax itself (or the v-ray plugin) failed, not Vantage.
    Nikola Goranov
    Chaos Developer
      I will try again when I have time, and I will post the latest news here if there is any.
