Phoenix foam/mist mesh not showing
  • Phoenix foam/mist mesh not showing
    Hi guys,
    Do you know how to get the mist or foam element from Phoenix within 3dsmax showing in Vantage?
    I can get the Phoenix source emitter object rendering by adding an edit mesh modifier in the stack, alas the foam and mist sub-component doesn't show up with the same modifier applied.
    Any help appreciated.
    Jason
    AMD Threadripper 3990x 64C Processor, 128 GB DDR4-3200 Ram, 48 GB PNY Quadro RTX A6000, ​Windows Pro 10.0.19045.4894, 3dsmax 2025.3, Vray 62006, Vantage 2.5.2​
    Hi Jason,
    Currently there isn't a way to render particles with foam or mist shader. If the particles have some geo volume to them then it should render fine in Vantage. We have such a request but I cannot give time frame when it will be implemented. We will inform you here or keep an eye on the Announcement category of the Vantage forum for the release notes on new releases.
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
      As always Alex thanks for the quick update.
      Kind regards,
      Jason
        Hi Jason,
        We haven't yet implemented support for particles but you can try this workaround with tyflow to generate spheres which will render in Vantage https://www.youtube.com/watch?v=T8OpSC7v8s8
        Best regards.
        Alexander​
        Alexander Atanasov
        Chaos
