QT problem
  • QT problem
    Hello
    I am getting this error recently : https://dl.dropboxusercontent.com/s/...731_104805.png
    I re-installed VRay to reinstall Chaos Cosmos, the problem was resolved for some time, but I have it once again.
    I believe this is related to the ChaosCosmos as it is related to the chromium engine used for browsing.
    Available for remote work.
    My LinkedIn: https://www.linkedin.com/in/olegbudeanu/
    Oh and it appears ONLY when I start vantage from 3dsmax. When I fire up vantage separately - everything is fine.
    And if I fire Vantage as a standalone first, and after that from 3dsmax - error disappears.
      This is related to the system's DLL search paths. It looks like Max is setting the search paths for Qt DLLs it provides (or V-Ray for Max or some other plugin) which are a different version than those in Vantage. Then vantage.exe and in turn qtwebengineprocess.exe are child processes that inherit the search paths and load the wrong DLLs. I don't think we've seen this issue lately, i.e. V-Ray 6 users haven't complained so far, so maybe it's something specific to your setup. What versions of Vantage, V-Ray and 3ds Max are you using? What other plugins do you have in Max?
      Nikola Goranov
      Chaos Developer
        There is one previous report for the same error here on the forum: https://forums.chaos.com/forum/chaos...n-cosmos-issue
        Do you have Dropbox installed? (it may or may _not_ have something to do with it)
        Nikola Goranov
        Chaos Developer
