Alpha Transparency and Save As Image PNG not working
  • Alpha Transparency and Save As Image PNG not working
    I have a setup with a backdrop which I've made alpha in Max.
    If I export this scene to Vantage then do a quick Save as Image out to .PNG, it loses it's backdrop/alpha channel.
    However, If I save it out to .EXR it keeps the alpha channel/works but generates a much larger file.
    I notice that if I try a "High Quality" rendering it gives the option to save out the Alpha for PNG in the popup dialog.
    Is there a way to get this to simply save out the Alpha channel under the file menu instead?
    Thanks.
    LunarStudio Architectural Renderings
    HDRSource HDR & sIBL Libraries
    Lunarlog - LunarStudio and HDRSource Blog
    Hi jujubee,
    There is an option Toggle in Edit>Preferences>Files called Opacity(alpha) in quick saved PNG. Enable this and it should save the png with alpha. Please tell us if it works for you.
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
