What are the defaults for Maxscript render animation with Vantage
  • What are the defaults for Maxscript render animation with Vantage
    Been having some issues and tried various adjustments, however cant remember what is defaults.
    Can you tell me what is default for samples and noise in the UI for the maxscript render animation with vantage please...
    Kind Regards,
    Morne
    The default UI value for noise threshold is 0.005 in the Max dialog and 0.01 in Vantage itself (yes, a bit inconsistent). The default sample count is 100. The settings are just a starting point as the result is scene dependent, YMMV, etc.
    Nikola Goranov
    Chaos Developer
      if I set samples to 0, would that mean it uses as much samples as needed to reach the noise threshold?
      Kind Regards,
      Morne
        I think this has been overlooked. It shouldn't allow 0 input. The app will default to 100 samples in this case. Vantage offline rendering always has a maximum number of samples.
        Nikola Goranov
        Chaos Developer
