No Vantage Toolbar in Sketchup
  • No Vantage Toolbar in Sketchup
    I enabled the Chaos Vantage toolbar in Sketchup, but no buttons appear. Has anyone else had this issue?
    Hi calvin_ode,
    When you enable the Chaos Vantage toolbar it doesn't automatically pin itself somewhere in the toolbars, it is floating somewhere on the screen. Maybe it appears on a second monitor that it is just too hard to notice?
    Alexander
    Alexander Atanasov
    Chaos
      If you are unable to locate a floating SketchUp toolbar, in this case "Chaos Vantage", please go to the SketchUp menu View > Toolbars, then ensure it is enabled and reset it.
      This should make the toolbar reappear somewhere close to the center of your main display.
      Note that the toolbar consists of a single button so it might be hard to spot at first.
      Peter Chaushev
      Let's keep in touch
        Hi Peter.Chaushev, I tried resetting the toolbar and it still didn't show up.
