About resolution
  • About resolution
    After real-time linking, it defaults to 1280 * 720. Even if I export from the. advantage configuration file
    It also does not save this parameter
    For this reason, I have to change the composition scale of the advantage every time to adapt to the composition scale of 3dsmax. Can this parameter be remembered?​
    Hi q976431,
    You have click the Save/Overwrite button next to the camera thumbnail after you set the resolution. A pop-up dialog will appear and ask ask you if you want to overwrite just the resolution or all parameters of the camera:https://drive.google.com/uc?id=1ZMOI...plhHTX69NciA9E This only appears if the camera you want to overwrite is imported from the vrscene and not created in Vantage(another difference between imported and created cameras is that only created cameras can be deleted and have a X button bellow the overwrite button: https://drive.google.com/uc?id=1T1go...qZxaj-Fnj_6Stk). After you reopen the scene click on the camera and the new resolution should be recalled. I will log an issue to see if we can improve this.
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
      Originally posted by Alexander.Atanasov View Post
      Hi q976431,
      Alexander
      It is hoped that the resolution of 3dsmax can be read when the real-time linkage is initialized
