VrayClipper in Vantage
  • VrayClipper in Vantage
    Hello, I tried to animate a VrayClipper in Vantage, but it doesn't work. I tried 3dsmax's Slice modifier, but it doesn't work. To date, is there a command I can use in Vantage to override the modifiers mentioned?
    thanks for help
    Hi radiosity1980,
    VRayClipper is currently not supported. However the Slice modifier should work correctly in Live link and 'Render animation with Chaos Vantage' and not when you export the animation to a vrscene. Can you try with the 'Render animation with Chaos Vantage' and see if it works for you?
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
      I tried to use the slice modifier, but it doesn't work
      Filippo
        Hi Filippo,
        In my test an animated slice modifier works through 'Render animation with Chaos Vantage'. Can you please send a scene to test?
        Alexander
        Alexander Atanasov
        Chaos
          Originally posted by Alexander.Atanasov View Post
          Hi Filippo,
          Alexander
          surely. Which email address should I send the file to?
          Filippo
            You could use the chaos help center here https://support.chaos.com/ to send the scene.
            Alexander​
            Alexander Atanasov
            Chaos
              Alexander​
              done! but,
              I also tried with a simple box with the slice applied, but it doesn't work. Maybe I am doing something wrong?
              Thanks for help
              Filippo​
                Hi Filippo,
                We received and examined the scene. All is working fine on our end: https://drive.google.com/uc?id=1KOPa...vUXe7Cnlz_vdUB. Can you please record your screen to see the steps you are doing?
                Alexander
                Alexander Atanasov
                Chaos
                  Hello, I found the problem. The slicer modifier works if you use LIVE LYNC, but if I use EXPORT and SEND ... it doesn't work in Vantage. I have attached a video.
                  Filippo​​​
                    Hi Filippo,
                    Yes, deformable meshes (which the box is in your case) from .vrscene will not work with the current version of Vantage (1.8.1.). We plan to add support for deforming meshes for vrscenes and other supported formats later. We will notify you when they are implemented.
                    Alexander
                    Alexander Atanasov
                    Chaos
