Some proxy objects with no textures
  • Some proxy objects with no textures
    Hi there,
    Why is it that sometimes a proxy object won't have textures assigned in Vantage - all you see is a bright object wirecolor?
    In 3dsMax everything renders correctly. File is saved as a vrscene, then opened in Vantage.
    All the assests are saved in the same network location, and 95% of the proxies are rendering correctly in Vantage - it's just here and there?
    Click image for larger version  Name:	Screenshot_Proxy Issue.jpg Views:	0 Size:	51.5 KB ID:	1164703
    Hi Philip,
    Sometimes when opening a scene from a network not all scene elements get loaded properly due to some kind of timeout(not from Vantage but from the network transfer) or similar. Can you try to open the scene from a local drive and see if the issue persists?
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
      Hi Alexander, will do a test.
      Thanks.
        All the assests are saved in the same network location, and 95% of the proxies are rendering correctly in Vantage - it's just here and there?​
        A pink/purple material color is used for unsupported materials.
        What are the materials assigned to these proxy objects ?
        Greetings,
        Vladimir Nedev
          Ahh yes Vladimir,
          I think that's the problem - I've opened the materials on the object and see it's got a Top/Bottom material assigned.
          That's also quite a dated type of material? I assume Vantage isn't supporting it.
          Will convert to Vantage appropriate material.
          Thanks for your help.
Name:	Screenshot_Proxy Material Issue.jpg
