Denoiser only on final pass
  • Denoiser only on final pass
    Hi there,
    I've done an animation render a few months ago with version 1.8.2 (maybe even 1.8.1) - was happy with noise quality.
    Yesterday with version 1.8.3 I had to do updates and brought in my settings via "Open scene as config only"
    The only thing I changed was clicking the Denoiser setting in rendering tab "only final pass"
    The result is significantly more noise grain - if I untick it, it looks much better.
    Is this to be expected? I assumed the final image would have been the same quality?
    Some images would be helpful. Is it noisier compared to 1.8.3 without the "only final" option or compared to 1.8.2? Have you tried "open as config" with 1.8.2?
    Nikola Goranov
    Chaos Developer
      Hi npg, difficult to show the noise problem with stills - it's only really visible when viewing the animation.
      1.8.3 is noiser with "only final pass" checked compared to unchecked option.
        We will try to reproduce this with our scenes...
        Nikola Goranov
        Chaos Developer
          Thanks npg,
          The config file I loaded was version 1.8.2 (​​​​​​​which didn't have the "final pass" option) which I loaded in to 1.8.3.
          Not sure if that may be a factor.
          When I disable "final pass" in 1.8.3 the noise level looks like the previous animation that was done in 1.8.2.
          When I enable "final pass" the noise is noticably more.
            Hi philip_nel,
            Can you please send us a scene where the issue easily reproduces and a video with the differences? You can use the support form from the Chaos Help Center and the support team will notify me when they receive your files.​
            Alexander​
            Alexander Atanasov
            V-Ray for Unreal & Chaos Vantage QA
            Chaos
