Hello i want to ask if the problem is solved maby i am wrong but if i check the Reduce flickering there is still flickering in the animation. Why that is happening can i do something to repair it?
Animation flickering
It's hard to guess. We would have to run a process of elimination to find out what causes this flickering. If I understand correctly the flickering is at least reduced, so the result is not identical to having the option turned off? It could be due to excessive noise. It could be from the light cache. Etc... If you have the time to experiment (maybe just render a few frames, not the whole thing), see how it looks raw; or with light cache turned off; or if you use 4x camera samples; or with maximum light tree samples if the scene has many light sources...Nikola Goranov
Chaos Developer
