Unable to transfer textures and VrayProxy objects into Chaos Vantage
  • Unable to transfer textures and VrayProxy objects into Chaos Vantage
    I am trying to export a .vrscene file from 3D Studio Max 2023 and bring the .vrscene file into Chaos Vantage on a remote machine that has much more GPU power.
    Not of the texture information or VrayProxy objects translate over to Chaos Vantage.
    Here are some screen shots showing the model in Max and the same model imported via .vrscene into Chaos Vantage.
Name:	Screenshot 2023-01-16 121955.png
ID:	1170234Click image for larger version
Name:	Screenshot 2023-01-16 122050.png
    I am using Vray materials, and importing the model of the person from Chaos Cosmo Browser.
    Any help would be greatly appreciated.
    Thank you Click image for larger version
ID:	1170236 Click image for larger version
    The vrscene file doesn't contain textures or the VRayProxy meshes (vrmesh files).
    You have to gather all these external files and copy them along the vrscene (in the same directory).
    One way to do this is to use File -> Archive from 3dsMax, unzip the generated .zip file on the remote machine and copy the vrscene file next to the unzipped .max file.
    You also need Vantage 1.8.3 (the last release).
    Greetings,
    Vladimir Nedev
      Specifically for Cosmos, it may be convenient to set it up with a shared network location for asset downloads.
      " Can I use the Cosmos Library in a shared network setup?
      The Chaos Cosmos browser currently supports any form of network install, including mapped drives, UNC paths, Google Drive/Dropbox/OneDrive. It also supports network setup."
      Nikola Goranov
      Chaos Developer
