Render with transparent background
  • Render with transparent background
    Hello,
    I want to render a png image with totally transparent background like this:
    When I put this image on my web site with ​black background, I got a white outline around the black cube:
    This issue is casued by white background setting:
    So I use an alpha=0 image as background like this:
    But unfortunately this could not fix this issue, so is there any way to remove this OUTLINE?
    Thanks.
    Hi baoxiaohe_developer,
    Currently that is not possible from within Vantage. You could try:
    • the Defringe option(Layer menu > Matting > Defringe) in Photoshop with 1-3 px width. That should remove that outline but may eat out more pixels than needed, eg thin lines may get erased.
    • the Remove White Mattes (Layer menu > Matting > Remove White Mattes)
    • set a black color as background in Vantage and render that out. This should work in your case when using a black background but will produces a black outline if you decide to change your web site's background.
    Please try it and report back if it works in your case.
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
      This didn't work for me. There is no "matting" option in the layers menu
