Forest Pack to Chaos Vantage
  • Forest Pack to Chaos Vantage
    I currently have iToo Forest Pack and I need to stage my export for Chaos Vantage. Are there any tips and tricks for making sure all of the files are in the proper location when exporting?
    Hi david_heath,
    I would suggest using the Archive packer option in the V-Ray scene exporter - https://docs.chaos.com/display/VMAX/...-ArchivePacker . It will gather all resources used in the scene and copy them to the specified 'Export Path' location next to the vrscene. If you enabled the 'Archive as zip' then al you need is to copy the generated zip file to your other work station or to a network drive which your other machines have access.
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
