Animation problem
  • Animation problem
    Hello I animated moving lights in max and i can render them using the button from the toolbar (render animation with chaos vantage) but im loosing the physical sky. Why is this happening?
    Hi Martin,
    Yes, this is expected behavior if the Physical sky is set in Vantage and not coming from Max when in Live link. Set the environment in Max and then render with the 'Render animation with Chaos Vantage' and everything should look as expected.
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
      The sky is dynamic animation. Can i put vray sky and environment and animate it in vantage sun menu?
        You can animate it in Max and it should work in Live link. Can you send a video of how you set the scene and what is happening exactly?
        Alexander Atanasov
        Chaos
          Thank you for the fast reply! I have to re-export the animation againt but at least I adjusted the sun very quickly with the same settings and everything is great. Its not as fast like directly in vantage but its a lot faster than all older methods. Thanks again!
