Vray Scatter get scaled in Vantage.
  • Vray Scatter get scaled in Vantage.
    When I use Scatter to create grass in Vray for Sketchup and then export it to a .vrscene file.
    After that, when I open the Vantage program and import that file, the scale of the grass is larger than the Scatter created.
    Can anyone help me fix it to the correct scale?
    I have attached a file to help you better understand.
    1. Does it render correctly with V-Ray CPU and GPU ?
    2. Which version of V-Ray for SketchUp are you using and which version of Vantage ?
    3. Can you attach the SketchUp file as well ?
    Greetings,
    Vladimir Nedev
      1. I use the latest Vray and Vantage versions.
      2. When using Vray or using Live link, the scale is still correct.
      Here are the files​.
        Hm, seems to be working for me.
        How do you import the vrscene with the scattered grass in Vantage - do you just "open" it or "place" it in another scene ?
        I tried Vantage 1.8.4.
        Click image for larger version  Name:	van184.png Views:	0 Size:	421.6 KB ID:	1175634
        Greetings,
        Vladimir Nedev
          Hi Vladimir,
          I imported by going to: File >> Import, but encountered a scaling error. However, when I tried File >> Open, the error was resolved. Thank you very much.
